Svp, lors du jailbreak "Ipsw" de "iphone 3gs  32 go,   ios: 6.1.6, N° série :86014", redsn0w_win_0.9.15b3 n'as pas pris en charge   " ios 6.0   10A403 " pour cause de
N° de serie. Mon sytseme est Win Seven 64 bits.
Voici le message reçu en orientant Ipsw 6.0 dans "Extra"
Is this newer model of the iphone 3GS? If you're not sure,you can determine your production week from the serial number in your setting-general-about screen.
The week number is usually the 4th and 5th digit of the serial number.For exemple,à SN beginning with 88926...would be week 29 of 2009.If the third  digit isn't 9, you definitely have a fixed bootrom.
3gs units made 2009 week 45 or later usually have a fixed bootrom.Before week 40, they usually have the older (desirable) one. Betwen week and 45,
Caution:if you have a newer model and you don't correctly identify it here,you will likely need to do a full official  restore to fix the mistake,losing any unsynced data.
Note that newer models cannot yet have custom logo
        oui      non
Je ne maîtrise pas l'anglais mais après  quelques acrobaties j'ai cru comprendre que mon iPhone est postérieur à 2009.
Un grand MERCI , pour l'aide apportée.
Ps/ J'ai été invité à ouvrir un nouveau sujet
