skamccd83 Posté(e) December 5, 2010 rapport Share Posté(e) December 5, 2010 bonjour! je m'explique j'ai un iphone en 4.2.1 suite a une restauration a cause d'un crash. j'aimerai downgrader mon phone afin de le jailbreaker a nouveau, j'ai donc utilisé tiny umbrella en appuyant sur save ssh et voici le rapport 12/05/2010 15:46:54.724 Loaded History... 12/05/2010 15:46:56.511 Caching shsh files... 12/05/2010 15:46:56.529 Found [4] shsh files to cache... 12/05/2010 15:46:56.536 Cached [4] shsh files 12/05/2010 15:46:57.349 Device connected: iPhone de MAX 12/05/2010 15:46:57.380 Loaded History... 12/05/2010 15:46:57.931 You are using the current version of TinyUmbrella. 12/05/2010 15:47:06.338 Started saving SHSHs for [iPhone de MAX ] 12/05/2010 15:48:02.772 This device isn't eligible for the requested build. 12/05/2010 15:48:02.788 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 4.0.1 (8A306) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 12/05/2010 15:48:03.506 This device isn't eligible for the requested build. 12/05/2010 15:48:03.521 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 4.0 (8A293) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 12/05/2010 15:48:07.764 You have saved your iPhone4 4.2.1 (8C148) SHSH locally and the request was sent to CYDIA. This means that CYDIA DOES have your SHSH. Do NOT bug semaphore about the Cydia home page showing this version. 12/05/2010 15:48:08.919 You have saved your iPhone4 4.2b3 (8C5115c) SHSH locally and the request was sent to CYDIA. This means that CYDIA DOES have your SHSH. Do NOT bug semaphore about the Cydia home page showing this version. 12/05/2010 15:48:10.728 You have saved your iPhone4 4.1 (8B117) SHSH locally and the request was sent to CYDIA. This means that CYDIA DOES have your SHSH. Do NOT bug semaphore about the Cydia home page showing this version. 12/05/2010 15:48:11.555 You have saved your iPhone4 4.0.2 (8A400) SHSH locally and the request was sent to CYDIA. This means that CYDIA DOES have your SHSH. Do NOT bug semaphore about the Cydia home page showing this version. 12/05/2010 15:48:11.618 Finished saving SHSHs for [iPhone de MAX ] 12/05/2010 15:48:11.727 Caching shsh files... 12/05/2010 15:48:11.742 Found [4] shsh files to cache... 12/05/2010 15:48:11.758 Cached [4] shsh files je suis un peu paumé ai je une solution et comment faire merci a tous de votre aide Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jhon Posté(e) December 5, 2010 rapport Share Posté(e) December 5, 2010 Tu as bien la dernière version ? http://www.iphone4.fr/sauvegardez-le-sh ... yumbrella/ Car elle indique logiquement en toute simplicité les shsh sauvegardés pour ton appareil. Lien vers le commentaire Partager sur d’autres sites More sharing options...
skamccd83 Posté(e) December 5, 2010 Auteur rapport Share Posté(e) December 5, 2010 oui j'ai la dernière version Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jhon Posté(e) December 5, 2010 rapport Share Posté(e) December 5, 2010 Et dans la fenêtre, une fois que tu as cliquer sur save my shsh ? tu as quoi ? un truc du genre ? iPhone4 4.0 (8A293) iPhone4 4.0.1 (8A306) iPhone4 4.1 (8B117) iPhone4 4.2.1 (8C148a) iPhone4 4.2b3 (8C5115c) Lien vers le commentaire Partager sur d’autres sites More sharing options...
skamccd83 Posté(e) December 5, 2010 Auteur rapport Share Posté(e) December 5, 2010 iPhone4 4.0.2 (8A400)-2358844064685 iPhone4 4.1 (8B117)-2358844064685 iPhone4 4.2.1 (8C148)-2358844064685 iPhone4 4.2b3 (8C5115c)-2358844064685 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jhon Posté(e) December 5, 2010 rapport Share Posté(e) December 5, 2010 Bon alors nikel Je te conseil la 4.1 ne t'en fais pas pour le baseband, ça le changera juste pas. Donc aucuns soucis Donc tu suis se tutoriel à la lettre ->http://www.iphone4.fr/jailbreaker-iphone-3g3gs-iphone-4-ios-4-1-sans-mettre-a-jour-le-baseband-windows-mac-os-x/ Tout en laissant Umbrella ouverte et "Start Tss Server" en route pendant toute le tuto. (jette un oeil avant le restauration avec le custom firmware) Enfin tu réinstalles ta sauvegarde, ouvres et met à jour cydia et logiquement tout devrait aller comme sur des roulettes. Lien vers le commentaire Partager sur d’autres sites More sharing options...
skamccd83 Posté(e) December 5, 2010 Auteur rapport Share Posté(e) December 5, 2010 il faut que je sauvegarde la 4.1 avec save ssh c'est ça ? merci 1000 fois jhon Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jhon Posté(e) December 5, 2010 rapport Share Posté(e) December 5, 2010 Pas de souci. (non si Umbrella te l'affiche dans la fenêtre quand t'as cliqué c'est que c'est bon. , touche rien clic juste sur "start tss server" avant de suivre le tuto.) Tiens nous au courant (mais tu avais peu être déjà sauvé les shsh via Cydia et le bouton "make my life easier") Mais en tout cas, c'est tout bon pour le tuto. (avec Umbrella et TSS Server en route) Lien vers le commentaire Partager sur d’autres sites More sharing options...
skamccd83 Posté(e) December 6, 2010 Auteur rapport Share Posté(e) December 6, 2010 salut ! ça y' est j'ai testé et tout a marché a merveille. merci encore jhon pour ton aide précieuse Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jhon Posté(e) December 6, 2010 rapport Share Posté(e) December 6, 2010 Nikel Profites bien Lien vers le commentaire Partager sur d’autres sites More sharing options...
