Bonjour a tous, Joyeux Noel.
Je viens d'acquerir un iPhone 4 désimlocker:
- Version 4.2.1 (8C148)
- Model MC605FB
- Modem Firmwire 03.10.01
Ma question est la suivante:
Comment sauvegarder en SHSH avec TinyUmbrella(version 4.21.01) ? Je viens de l'essayer à plusieurs reprises et le message d'erreur est le suivant:
12/26/2010 13:55:08.115 Started saving SHSHs for [iPhone 4 Dave#9] 12/26/2010 13:55:08.282 iPhone 4 Dave#9-iPhone4 4.0 (8A293) is already in progress! 12/26/2010 13:55:08.310 iPhone 4 Dave#9-iPhone4 4.0.2 (8A400) is already in progress! 12/26/2010 13:55:08.317 iPhone 4 Dave#9-iPhone4 4.1 (8B117) is already in progress! 12/26/2010 13:55:08.326 iPhone 4 Dave#9-iPhone4 4.2.1 (8C148) is already in progress! 12/26/2010 13:55:15.403 You have saved your iPhone4 4.2.1 (8C148) SHSH locally and the request was sent to CYDIA. This means that CYDIA DOES have your SHSH. Do NOT bug semaphore about the Cydia home page showing this version. 12/26/2010 13:56:11.087 This device isn't eligible for the requested build. 12/26/2010 13:56:11.099 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 4.0.1 (8A306) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 12/26/2010 13:56:15.078 This device isn't eligible for the requested build. 12/26/2010 13:56:15.094 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 4.0 (8A293) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 12/26/2010 13:57:02.335 This device isn't eligible for the requested build. 12/26/2010 13:57:02.348 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 4.2b3 (8C5115c) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 12/26/2010 13:57:09.452 This device isn't eligible for the requested build. 12/26/2010 13:57:09.474 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 4.1 (8B117) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 12/26/2010 13:57:56.148 This device isn't eligible for the requested build. 12/26/2010 13:57:56.162 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 4.0.2 (8A400) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 12/26/2010 13:57:56.175 Finished saving SHSHs for [iPhone 4 Dave#9] 12/26/2010 13:57:56.370 Caching shsh files... 12/26/2010 13:57:56.393 Found [1] shsh files to cache... 12/26/2010 13:57:56.414 Cached [1] shsh files
Que faire pour pouvoir comme même sauvegarder et comment jailbreaker de meilleur manière?
Merci.
Sur umbrella t'as pas un shsh en 4.2.1 dans la fenêtre "général" ?
Sinon pour se qui est du jailbreak, je te conseil d'attendre un peu. Car en 4.2.1 il est tethered donc pas pratique du tout.
Mais cela ne saurait tarder, suit l'actualité sur le blog, un tutoriel sera disponible dès que cela sera possible et testé.
