Je tente de jailbreaker un Ipad 2 3g 32go et quand je tente de sauver mon shsh j'ai ce message :
04/06/2012 09:36:55.447 Loaded History...
04/06/2012 09:36:59.644 Caching shsh files...
04/06/2012 09:36:59.644 Found [0] shsh files to cache...
04/06/2012 09:36:59.644 Cached [0] shsh files
04/06/2012 09:36:59.644 You are using the current version of TinyUmbrella.
04/06/2012 09:37:08.775 Device connected: ipad de
04/06/2012 09:37:08.791 Loaded History...
04/06/2012 09:37:49.411 Started saving SHSHs for [ipad de ]
04/06/2012 09:37:53.311 For version [iPad23G 5.1 (9B176)] - This device isn't eligible for the requested build.
04/06/2012 09:37:53.311 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 5.1 (9B176) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:53.342 For version [iPad23G 4.3.5 (8L1)] - This device isn't eligible for the requested build.
04/06/2012 09:37:53.342 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 4.3.5 (8L1) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:54.060 For version [iPad23G 5.1b1 (9B5117b)] - This device isn't eligible for the requested build.
04/06/2012 09:37:54.060 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 5.1b1 (9B5117b) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:54.122 For version [iPad23G 5.0b6 (9A5302b)] - This device isn't eligible for the requested build.
04/06/2012 09:37:54.122 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 5.0b6 (9A5302b) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:54.715 For version [iPad23G 4.3.1 (8G4)] - This device isn't eligible for the requested build.
04/06/2012 09:37:54.731 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 4.3.1 (8G4) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:54.777 For version [iPad23G 4.3.3 (8J2)] - This device isn't eligible for the requested build.
04/06/2012 09:37:54.793 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 4.3.3 (8J2) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:55.167 For version [iPad23G 5.0b4 (9A5274d)] - This device isn't eligible for the requested build.
04/06/2012 09:37:55.183 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 5.0b4 (9A5274d) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:55.386 For version [iPad23G 5.0.1 (9A405)] - This device isn't eligible for the requested build.
04/06/2012 09:37:55.386 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 5.0.1 (9A405) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:55.651 For version [iPad23G 5.0b2 (9A5248d)] - This device isn't eligible for the requested build.
04/06/2012 09:37:55.651 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 5.0b2 (9A5248d) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:56.244 For version [iPad23G 5.0 (9A334)] - This device isn't eligible for the requested build.
04/06/2012 09:37:56.244 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 5.0 (9A334) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:56.337 For version [iPad23G 5.1b2 (9B5127c)] - This device isn't eligible for the requested build.
04/06/2012 09:37:56.337 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 5.1b2 (9B5127c) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:56.930 For version [iPad23G 5.0b7 (9A5313e)] - This device isn't eligible for the requested build.
04/06/2012 09:37:56.930 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 5.0b7 (9A5313e) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:57.102 For version [iPad23G 5.0b5 (9A5288d)] - This device isn't eligible for the requested build.
04/06/2012 09:37:57.102 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 5.0b5 (9A5288d) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:57.383 For version [iPad23G 5.0b3 (9A5259f)] - This device isn't eligible for the requested build.
04/06/2012 09:37:57.383 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 5.0b3 (9A5259f) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:57.710 For version [iPad23G 5.0b1 (9A5220p)] - This device isn't eligible for the requested build.
04/06/2012 09:37:57.726 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 5.0b1 (9A5220p) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:57.991 For version [iPad23G 4.3.4 (8K2)] - This device isn't eligible for the requested build.
04/06/2012 09:37:58.007 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 4.3.4 (8K2) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:58.397 For version [iPad23G 4.3.2 (8H7)] - This device isn't eligible for the requested build.
04/06/2012 09:37:58.397 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 4.3.2 (8H7) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:58.646 For version [iPad23G 5.1b3 (9B5141a)] - This device isn't eligible for the requested build.
04/06/2012 09:37:58.646 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 5.1b3 (9B5141a) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:59.005 For version [iPad23G 4.3 (8F191)] - This device isn't eligible for the requested build.
04/06/2012 09:37:59.021 CYDIA DOES NOT HAVE YOUR SHSH FOR iPad23G 4.3 (8F191) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
04/06/2012 09:37:59.036 Finished saving SHSHs for [ipad de ]
04/06/2012 09:37:59.052 Caching shsh files...
04/06/2012 09:37:59.067 Found [0] shsh files to cache...
04/06/2012 09:37:59.099 Cached [0] shsh files
J'ai merdé ou a votre avis?
Décoche la case avec Cydia dedans dans l'onglet advanced.
Mais tu sauvera que le 5.1, tous les autres c'est trop tard
Et s'il est en 5.1, cherche pas, pas de jailbreak pour le moment.
