frenche1 Posté(e) April 24, 2012 rapport Share Posté(e) April 24, 2012 Bonjour à tous. J'essaye depuis 2 jours de mettre à jour un iPhone 4 4.3.3 boot tethred. Je suis mac, pas de SHSH de sauvegardé, drnières versions des programes installées. 04/24/2012 12:00:47.245 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 5.1 (9B176) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 04/24/2012 12:00:47.904 For version [iPhone4 5.0.1 (9A405)] - This device isn't eligible for the requested build. 04/24/2012 12:00:47.920 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 5.0.1 (9A405) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 04/24/2012 12:00:48.057 For version [iPhone4 5.0b7 (9A5313e)] - This device isn't eligible for the requested build. 04/24/2012 12:00:50.951 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 4.3.5 (8L1) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 04/24/2012 12:00:51.294 For version [iPhone4 5.1b3 (9B5141a)] - This device isn't eligible for the requested build. 04/24/2012 12:00:51.314 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 5.1b3 (9B5141a) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 04/24/2012 12:00:51.674 For version [iPhone4 4.3.4 (8K2)] - This device isn't eligible for the requested build. 04/24/2012 12:00:51.700 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 4.3.4 (8K2) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 04/24/2012 12:00:52.021 For version [iPhone4 4.3.3 (8J2)] - This device isn't eligible for the requested build. 04/24/2012 12:00:52.038 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 4.3.3 (8J2) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 04/24/2012 12:00:52.532 For version [iPhone4 4.3.2 (8H7)] - This device isn't eligible for the requested build. 04/24/2012 12:00:52.556 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4 4.3.2 (8H7) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE. 04/24/2012 12:00:52.835 For version [iPhone4 4.3.1 (8G4)] - This device isn't eligible for the requested build. J'ai plusieurs erreurs aux choix, aussi bien avec Firmware 5.0.1 original que modifier (via Pwnage Tool) Via server TSS TinyUmbrella : Erreur 11 (firmware original + modifié) TinyUmbrella arrêté: (Firmware original + modifié) Erreur device isn't eligible Copie du fichier hosts ## # Host Database # # localhost is used to configure the loopback interface # when the system is booting. Do not change this entry. ## 127.0.0.1 localhost 255.255.255.255 broadcasthost ::1 localhost fe80::1%lo0 localhost #74.208.10.249 gs.apple.com #127.0.0.1 gs.apple.com Et maintenant en modifiant le fichier hosts TinyUmbrella arrêté: (Firmware original + modifié) Erreur device isn't eligible ## # Host Database # # localhost is used to configure the loopback interface # when the system is booting. Do not change this entry. ## 127.0.0.1 localhost 255.255.255.255 broadcasthost ::1 localhost fe80::1%lo0 localhost 74.208.10.249 gs.apple.com P.S: Merci d'avance du coup de main. Lien vers le commentaire Partager sur d’autres sites More sharing options...
claude Posté(e) April 24, 2012 rapport Share Posté(e) April 24, 2012 sur ton host supprime ça #74.208.10.249 gs.apple.com #127.0.0.1 gs.apple.com et enregistre Lien vers le commentaire Partager sur d’autres sites More sharing options...
frenche1 Posté(e) April 24, 2012 Auteur rapport Share Posté(e) April 24, 2012 Toujours le même problème (firmware Apple + modifié): This device isn't eligible for the requested build. Lien vers le commentaire Partager sur d’autres sites More sharing options...
claude Posté(e) April 24, 2012 rapport Share Posté(e) April 24, 2012 Toujours le même problème (firmware Apple + modifié): This device isn't eligible for the requested build. tu a supprimé dans le host 74.208.10.249 gs.apple.com tout les gs.apple.com ou pas et aprés il faut que tu enregistre ça vire #74.208.10.249 gs.apple.com #127.0.0.1 gs.apple.com Lien vers le commentaire Partager sur d’autres sites More sharing options...
frenche1 Posté(e) April 24, 2012 Auteur rapport Share Posté(e) April 24, 2012 tu a supprimé dans le host 74.208.10.249 gs.apple.com tout les gs.apple.com ou pas et aprés il faut que tu enregistre ça vire #74.208.10.249 gs.apple.com #127.0.0.1 gs.apple.com Oui j'ai tout viré il ne reste plus que ## # Host Database # # localhost is used to configure the loopback interface # when the system is booting. Do not change this entry. ## 127.0.0.1 localhost 255.255.255.255 broadcasthost ::1 localhost fe80::1%lo0 localhost Lien vers le commentaire Partager sur d’autres sites More sharing options...
claude Posté(e) April 24, 2012 rapport Share Posté(e) April 24, 2012 bon la ouvre itune et fait une mise a jours en 5.1 et jailbreak aprés avec redsn0w Lien vers le commentaire Partager sur d’autres sites More sharing options...
xdechir Posté(e) April 25, 2012 rapport Share Posté(e) April 25, 2012 L'équipe d'iPhone4.fr est ravie d'avoir pu vous aider. N'hésitez pas à ouvrir un nouveau sujet dans les forums du Support Technique si vous avez d'autres questions. Merci et à bientôt sur iPhone4.fr Lien vers le commentaire Partager sur d’autres sites More sharing options...
