[Résolu] probleme de sauvegarde shsh avec tiny umbrella
titou1314
bonjour ,
j'ai un iphone 4s sous ios 6.0.1 ,j'ai voulu faire une sauvegarde des shsh que je n'ai encore jamais faite et ca ne marche pas
j'ai suivi le tuto : http://blogosquare.com/tinyumbrella-sauvegardez-vos-shsh-des-ios-6-0-et-6-0-1-mac-et-windows/
je choisis le dossier ou sauvegardé et je lance "save shsh" et il n'y a rien
voila le log si quelqu'un aurait une idée pour que je puisse faire cette sauvegarde ,merci d'avance
09/29/2013 21:59:08.457 Started saving SHSHs for [iPhone sandrine]
09/29/2013 21:59:09.944 For version [iPhone4S 6.0.1 (10A523)] - This device isn't eligible for the requested build.
09/29/2013 21:59:09.959 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 6.0.1 (10A523) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:10.420 For version [iPhone4S 5.0.1 (9A405)] - This device isn't eligible for the requested build.
09/29/2013 21:59:10.450 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 5.0.1 (9A405) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:10.722 For version [iPhone4S 5.1b1 (9B5117b)] - This device isn't eligible for the requested build.
09/29/2013 21:59:10.738 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 5.1b1 (9B5117b) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:10.890 For version [iPhone4S 5.1b3 (9B5141a)] - This device isn't eligible for the requested build.
09/29/2013 21:59:10.906 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 5.1b3 (9B5141a) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:11.243 For version [iPhone4S 6.0b2 (10A5338d)] - This device isn't eligible for the requested build.
09/29/2013 21:59:11.369 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 6.0b2 (10A5338d) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:11.641 For version [iPhone4S 5.1.1 (9B206)] - This device isn't eligible for the requested build.
09/29/2013 21:59:11.661 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 5.1.1 (9B206) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:12.080 For version [iPhone4S 6.0b4 (10A5376e)] - This device isn't eligible for the requested build.
09/29/2013 21:59:12.100 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 6.0b4 (10A5376e) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:12.414 For version [iPhone4S 5.0 (9A334)] - This device isn't eligible for the requested build.
09/29/2013 21:59:12.455 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 5.0 (9A334) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:12.483 For version [iPhone4S 5.1b2 (9B5127c)] - This device isn't eligible for the requested build.
09/29/2013 21:59:12.516 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 5.1b2 (9B5127c) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:12.976 For version [iPhone4S 5.1 (9B179)] - This device isn't eligible for the requested build.
09/29/2013 21:59:13.000 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 5.1 (9B179) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:13.027 For version [iPhone4S 5.0.1b (9A406)] - This device isn't eligible for the requested build.
09/29/2013 21:59:13.095 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 5.0.1b (9A406) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:13.583 For version [iPhone4S 6.0b1 (10A5316k)] - This device isn't eligible for the requested build.
09/29/2013 21:59:13.605 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 6.0b1 (10A5316k) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:13.628 For version [iPhone4S 6.0b3 (10A5355d)] - This device isn't eligible for the requested build.
09/29/2013 21:59:13.648 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 6.0b3 (10A5355d) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:14.395 For version [iPhone4S 6.0 (10A403)] - This device isn't eligible for the requested build.
09/29/2013 21:59:14.417 CYDIA DOES NOT HAVE YOUR SHSH FOR iPhone4S 6.0 (10A403) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
09/29/2013 21:59:14.438 Finished saving SHSHs for [iPhone sandrine]
09/29/2013 21:59:14.815 Caching shsh files...
09/29/2013 21:59:14.837 Found [0] shsh files to cache...
09/29/2013 21:59:14.901 Cached [0] shsh files
Bonsoir, :)
Avec tinyumbrella , on ne peut sauver les SHSH que de l'iOS ACTUEL, c'est à dire, ce soir du 7.02! ;)
Donc, avec ton 4s , lorsque tu cliques sur save m'y SHSH , tu n'auras que ceux du 7.02.
Si tu coches la case request from cydia dans l'onglet advanced, tu auras ceux qui ont été sauvegardés, uniquement si tu l'avais fait auparavant! :(
Pour les iPhones 4 et 3 GS, tu peux sauvegarder les SHSH de l'iOS présent sur ton iPhone.
Mais pour le 4s et les 5, iFaith, ne fonctionne pas!
Afin de voir les SHSH de ton iPhone, dans tinyumbrella, tu regardes en haut , à gauche et tu cliques sur ton iPhone et là tu verras ceux que tu as. ;)
Mais dans ton cas, je pense que tu n'en n'auras pas d'autre que le 7.02! :(
merci pour la reponse rapide
dans l'onglet general il n'y en a aucun dans "saved shsh"
ca veut dire que si je veux les sauvegardé il faut que je fasse la mise a jour de l'iphone pour le mettre sous le dernier ios ,c'est bien ca?
ca change quoi de le mettre à jour ? en tant que specialiste de cet appareil vous me conseillez de faire quoi?(rester comme ca ou faire la maj puis la sauvegarde?)
encore merci
Alors , pour sauver tes SHSH, dans ton cas précis, je n'en vois pas trop l'intérêt ! :)
Un 4s ou un 5, on ne peut pas les downgrader :(
Donc, le tout dépend uniquement de ce que tu veux! ;)
Si tu veux le nouvel iOS, fais une mise à jour, avec son nouveau design et ses nouvelles fonctions
Si tu ne le veux pas et tu préfères le 6.x, ne fais rien! :D
Le tout est une histoire de goût et de puissance, plus l'iOS est nouveau, plus il est gourmand en mémoire vive! :(
Perso, j'ai un 5 en 6.1.4 et je ne passes pas en 7 , car j'attends le jb unthetered , et je n'aime pas son design.
Mais c'est perso! :P
merci pour ton avis
si le 7 est gourmand en memoire vive ,il doit surement l'etre aussi en batterie ,ce qui n'est pas trop le point fort de l'iphone (pour moi)
je vais le laisser sur le 6 ,pour le moment ca me va tres bien
et puis je vais laisser tomber les sauvegarde de shsh puisque apparement ca ne sert pas a grand chose pour moi (je croyais que c'etait important d'avoir une sauvegarde comme je savais pas trop a quoi ca servait)
merci beaucoup pour ces renseignements
